TheGrumpyGent
Apr 21, 2022Tutor
Issue w Wireless Options with Insight Managed Orbi
In the Netgear Orbi Pro (SXR80), there is an option in wifi setup that supports "WPA2-Personal [AES] + WPA3-Personal". I had everything setup local, then tried to add the router to Insight managemen...
DaneA
Apr 21, 2022NETGEAR Employee Retired
What is the current firmware version of your SXR80?
Do you have an Insight Premium subscription or Insight Pro subscription?
Kindly post screenshots that shows "WPA2-Personal [AES] + WPA3-Personal" locally and Security page in Insight wherein it shows no option for "WPA2-Personal [AES] + WPA3-Personal."
DaneA
NETGEAR Community Team
TheGrumpyGent
Apr 22, 2022Tutor
DaneA
Hi dane , thanks for the reply! I have the Insight Premium sub that comes with the SXR80, and I have the latest firmware (V4.2.0.122).
I've attached a screenshot of the security options from within the Insight portal, as well as the options visible within the local admin UI. You can see the "WPA2-Personal [AES] + WPA3-Personal" option isn't available from Insight.
- TheGrumpyGentApr 22, 2022Tutor
Here is the Insight Portal options (only let me have one attachment at a time 🙂
Hi DaneA , please let me know what you find.
- TheGrumpyGentApr 24, 2022Tutor
Also, as a side question: If I go back into the local UI and change the settings back to WPA3 + WPA2, the Insight portal shows the network as having no encryption (shows "None"). The local UI shows the WPA3 + WPA2.
1) Which is correct? Is it just the Insight portal not having the option so shows "None" even though my wifi is protected, or is Insight actually turning off any encryption for the wifi network?
2) If I change the setting from the local UI, will Insight overwrite it anyway?
