FINITEREX's avatar
Dec 20, 2020
Mesh Topology Preferred Backhaul Ignored
Can anyone tell me why the "Preferred Backhaul" setting seems to be ignored for Mesh Toplogy? I've set mine to 2.4ghz yet the WAX610 "Extender" appears to be connecting over 5ghz to the other WAX610 "Root" (assuming what Insight tells me is true as there's no way to check on the AP itself)
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi FINITEREX
    When the preferred backhaul configuration is set from the Insight UI, then the extender will try to connect with the configured preferred root AP in the preferred band for 1 minute. If it is unable to establish a mesh connection within that time then the flag will be reset.Next Extender will fall back to the auto mode  and try to establish the connection with the root in the order of 5GHz High, 5GHz Low, and 2.4GHz. In this way, the extender could have established Mesh in the 5GHz band.
    Please download the detailed logs from both AP's monitoring UI and send it to me via PM.
    Thanks,
    Raghu
    • FINITEREX's avatar
      FINITEREX
      Guide
      Hi RaghuHR
      I have checked and the extender is always falling back to 5ghz auto, no matter that I set to prefer 2.4ghz. I've tried this with the APs next to each other in the bench. Appears this functionality is buggy.
      • RaghuHR's avatar
        RaghuHR
        NETGEAR Expert
        Hi FINITEREX
        Please download the detailed l;ogs from monitoring page and send us the link to download the logs. You can PM me the link.
        Thx,
        Raghu
ProSupport for Business
