sbs101
Sep 15, 2022Tutor
Multiple PoE Downtime Schedules for a single Port
We have multiple WAX610 APs connected to GC728XP switches managed via NETGEAR Insight Pro 6.8.4.10. We had set up daily PoE-Downtimes for all the ports serving the APs to save energy during the nigh...
JeraldM
Sep 15, 2022NETGEAR Employee Retired
Welcome to the community!
Just to clarify, you basically want to assign two PoE Downtime Schedules on a single port where the first schedule is set from 10 PM to 6 AM during weekdays and the second schedule is set all day during weekends.
If that is the case, the following configuration is not possible since you can only assign one PoE Downtime Schedule on a certain port.
JeraldM
NETGEAR Community Team
sbs101
Oct 16, 2022Tutor
Thanks for the answer.
It would be nice, if this feature could be implemented in an upcoming version of insight, as it is a pity that extended measures to save energy like these are not possible due to restrictions of the insight surface while it would be possible to configure them directly on the web surface of the switches themselves.
