ComputerMikes
Feb 11, 2019Guide
Netgear Insight, Feature Request/Issue Resolution
As part of the beta test group for the WAC540, I was unable to really evaluate the product as much as I wanted due to lack of a switch that could power it up and when I ordered a GC510PP to replace m...
schumaku
Feb 12, 2019Guru - Experienced User
ComputerMikes wrote:
schumaku wrote:
Hey I get your point! In my opinion WiFi scheduling must be per SSID - infrastructure, IoT, back office has to continue working when guests are off. The PoE schedule on the switch would kill down the AP completely, the global radio schedule is pretty much for the aluminium hat people 8-)Exactly! the WAC730 has it built in, ... per SSID. :)
Very similar, the WAC505/510 have it built-in - per SSID - but only available in standalone management mode. Convinced the WAC540 should have it, too.
RaghuHR
Feb 13, 2019NETGEAR Expert
From the logs we could see
- You have created three SSID with different vlan (1, 9 and 10).
- The SSID configured with vlan 10, is having FB captive portal enabled, in which the clients are not getting IP address.
- Since the captive portal is enabled in that SSID, AP is trying to get the IP from back-end for brvlan10 interface. From the logs we are able to see that the AP sending the dhcp discover but it is not getting any response from dhcp server. So clients are also not able to get IP address.
Please check why DHCP server is not responding.
Thanks,
Raghu
- ComputerMikesFeb 13, 2019Guide
Thanks,
Raghu
So after doing a bit of figuring (Insight management of the GC510PP is not as straight-forward as in standalone mode when it comes to tagging/untagging ports) I was able to find out that each VLAN has to have the uplink port set as a trunk individually. I'm totally NOT used to that and never have seen it done that way.
Now, my phone, an android, is getting an IP address, but it not getting prompted for capture portal for signin.
