MattyiceNG
Jan 11, 2024Aspirant
Network Topology & Security Question
Ok I have a fairly complex topology question/issue. I have my Orbi Pro 6 SXK80 all set up with the VLANS configured as follows: Port 1 - LAN 1 - VLAN 1 Admin Port 2 - LAN 2 - VLAN 2 Employees ...
schumaku
Jan 12, 2024Guru - Experienced User
ErwinL wrote:
VLAN 4/Port 4
You can simply connect and setup an access point for guest wifi access.
Dear ErwinL
Can the DHCP server and routing et all being fully deactivated to allow plugging a standalone router for serving the VLAN?
Just curious,
-Kurt.
MattyiceNG
Jan 14, 2024Aspirant
Thank you for time and thoughtful answers. Yes, I believe I can do that.
