MattyiceNG
Jan 11, 2024Aspirant
Network Topology & Security Question
Ok I have a fairly complex topology question/issue. I have my Orbi Pro 6 SXK80 all set up with the VLANS configured as follows: Port 1 - LAN 1 - VLAN 1 Admin Port 2 - LAN 2 - VLAN 2 Employees ...
schumaku
Jan 17, 2024Guru - Experienced User
ErwinL wrote:
Do you mean when disabling the DHCP server function and the routing of the main router. It's possible to connect a new router to one of the network and supply VLAN to such network?
Yes, this is what I understand the OP intends to do - what is easy in the sense of a single network covering multiple VLANs and flexible router deployments can proof to be challenging if not difficult when trying to combine multiple systems including another vendor. Last but not least, Google Nest does also have Mesh options what makes the project even more complex. Said this: I'm not to deep (or deep enough) in the Orbi Pro WiFi 6 systems -and- the Google Nest environment.
ErwinL
Jan 19, 2024NETGEAR Moderator
Hi@schumaku,
Yes this is possible. A device should use the default gateway IP address only when they intent to go out the main router or out the internet.
Have a lovely day,
Erwin
Netgear Team
- ErwinLJan 30, 2024NETGEAR Moderator
Hello@MattyiceNG
Was your problem resolved? If yes, in this case could you give us a feedback on the situation and accept the post as a solution to make it more visible to other users?
Thanks in advance! 🙂
Have a lovely day,
Erwin
Netgear Team
