TamactiJun
Mar 01, 2023Aspirant
Red flagged networkport on switch GS108Tv3 in Insight + How to reach Insight support
Hallo, Problem number 1: Last few months I often experience this problem and I don't know what causes it! As can be seen in the uploaded screenshot, the network port is flagged red. Sometimes ther...
abacqdghfth
Mar 03, 2023Guide
DM with e-mails ID to reach Insight team.
for WLAN deployments you can use this form
https://www.netgear.com/av/services/prowifi-designsupport/
more information on support context are below :
https://www.netgear.com/business/services/prosupport/
https://my.netgear.com/support/contact.aspx#
TamactiJun
Mar 04, 2023Aspirant
Thanks for reply. However after using link, it seems not to be the right place.
Have tried in few browsers to fill the form and submit, but it opens blank page with:
https://survey.netgear.com/ProaVWIFI?errMsg=An+error+occurred+updating+the+data+extension
Have tried everything.
When works support at NetGear if it doesn't work in Insight mobile app and now after 5 times using different browsers on two pc's?
It's more trouble and time trying to get Insight Support than that I try alone to find a solution. Is that behind all those curtains?
Have also sent an mail. So, after so many trouble I can't accept your post as solution. Let's give it a time to find out what it realy works how to get that NETGEAR support.
