ketchuphed
Jan 17, 2018Aspirant
Resource validation error when attempting to sign in to Insight
I have been unable to sign in to the Insight for about 2 weeks now. When attempting to sign in with my username and password i get "Unable to sign in. Resource validation error" with a Try Again butt...
- Feb 21, 2018Kohdee, I am on Android. I am manually typing the email address.
I have found an unsatisfying solution by changing the email address associated to my account. This has allowed me to log in. It is unfortunate that the system did not support the initial address I provided, as all other Netgear services accepted it as valid.
Thank you
SalauddinK
Jan 17, 2018NETGEAR Expert
Hi ketchuphed
As i could understand, you were unable to Sign in to the Netgear Insight App. (With resource validation error)
You had reset the password using forgot password & you are now able to login with the new password.
Could you help us with more Info
1. Was this Netgear account created from the Netgear Insight App ?
If not how did you create this account.
2. Is the Issue resolved now, with the new password.
Thanks,
SalauddinK
ketchuphed
Jan 22, 2018Aspirant
This profile was created within the insight app when I was initially setting up my access point
This issue is not resolved. I am able to log in to community.netgear.com and my.netgear.com through browser, but unable to log in with the app. Still seeing Resource Validation Error.
I have also replied to your Private Message SalauddinK
- DaneAJan 25, 2018NETGEAR Employee Retired
I just want to follow-up. The Insight maintenance has been completed. Are you still having the same problem?
DaneA
NETGEAR Community Team- ketchuphedJan 31, 2018Aspirant
Sorry for the silence.
No, I still receive "Resource Validation Error" when attempting to sign in to the Netgear Insight App
- SalauddinKJan 31, 2018NETGEAR Expert
Hi ketchuphed
The Error issue posted by you was also reported internally.
Fix for the Issue would be rolled out in the upcoming Insight Updates.
Will keep you informed as and when the updates are available.Appreciate your patience.
Thanks,
Salauddin
