Wireless Access Points
4 TopicsResource validation error when attempting to sign in to Insight
I have been unable to sign in to the Insight for about 2 weeks now. When attempting to sign in with my username and password i get "Unable to sign in. Resource validation error" with a Try Again button. I used the Forgot Password link to successfully reset my password, and am able to log in to the website using these credentials. Also, if I enter credentials I know are incorrect I get the error stating "Check the user name and password." I have also uninstalled and reinstalled the Insight App.Solved12KViews0likes12CommentsInsight Management App and Access Control
Hi, Not sure how many of you use Access Control Lists (Allow Mode) with your configurations. I have recently added three WAC 510 APs to my configuration. Prior to that I just used a Netgear Nighthawk X6 R8000 for all my Wifi needs. Being somewhat obsessive about things, I have been using Access Control for all of the devices that connect to my router. That ACL is still in effect now, even though I have all but one wireless devices now connected to the APs. Although I'm not sure why I'm so obsessive about this (another topic), I would like to transition my Access Control from the router to the APs. I am managing those APs using the Insight Management App. I haven't been able to find any way to batch input allowed MAC addresses for the APs. There was a way, although with some bugs, when I was managing the APs locally via a web browser. Is there a batch method, or do I have to painfully enter the MAC addresses one at a time for each AP via the app?2.8KViews0likes1CommentA Message to Insight 2.x customers from the NETGEAR Insight Team!
Hi Everyone, Greetings from NETGEAR. As a follow up to our earlier communication regarding upgrading from Insight 2.0/2.x to our new remote access, cloud-based Insight solution, we want to remind you that at the end of this year we’ll be ending support for Insight 2.0/2.x. We encourage you to upgrade to Insight 3.1 - our new cloud-based Insight - as soon as possible. Migrating will give you the opportunity to enjoy the many advantages of the Insight cloud platform as well as the features in Insight 3.1 managing a broader range of devices – access points, switches, and storage. Here are links to the Apple App Store and Google Play store to upgrade. Apple iOS Google Android As the year comes to a close, we want to take the opportunity to thank you for continuing support for NETGEAR and to wish you the very best for 2018. Thank you, The NETGEAR Insight Team What do I need to know about the transition to Insight 3.0?2.4KViews0likes0Comments
