Wireless Access Points
14 TopicsWhere are the firmware updates?
I'm baffled. I get emails from Netgear announcing firmware updates: Email January 23rd Firmware Details: Model WAX630E Firmware Version: 12.5.0.14 Email January 23rd Firmware Details: Model WAX620 Firmware Version: 12.5.0.15 I manage these myself directly via IP, so I log into the AP and click the Check for Upgrade button. It tells me there's no new firmware. It shows I'm using V11.8.0.9. The product page for the 630E shows 11.8.0.9 is the latest: https://www.netgear.com/support/product/wax630e So what's going on here? Why am I getting emails announcing new firmware that Netgear doesn't offer for download and my AP can't see to grab?Solved315Views0likes1Commentwax218 SSID CONFIG-ONLY unable to connect to then interface
hello, I have a pc which is connected to internet via a cable. I connect to ssid CONFIG-ONLY of my wax218... i could ping my wax218... but when i try to access ti http://192.168.100.1 my navigator displayed You have arrived at this page, mostly likely because you are currently not connected to your NETGEAR Business WiFi products. To access aplogin.com, aplogin.net, routerlogin.com or routerlogin.net, your device must be connected to your Router or Access Point’s WiFi network. what is the solution? thanks anthonynetgear wax218 webinterface
Na wat irritatie van de wax218. Omdat het niet duidelijk is hoe je de vlan-instellingen correct moet instellen. De wax werkt, dat geeft internet en de vlans werken ook. Maar ik kan alleen bij de webinterface komen via de cinfigonly ssid. Zelfs met de instelling uitgeschakeld. Ik kan dus niet bij de webinterface komen. Lan en elke ssid behalve de configonly ssid. Kan iemand dan repareren en een nieuwe firmware uploaden. BedanktWireless controller onpremise vs cloud
I have several wireless access points. The roaming between them doesn't work well due to sticky wifi so I'm considering working with a controller that manages the wireless roaming I know this can be done with a onpremise controller like the WC7600, but that is quite expensive to use in a small installation. I can't find anywhere if this forced roaming management is possible using the cloud controller - Insight. A complete comparison between the possibilities of the onprem and the cloud would be useful. thanks for clarification.Review WAC540 - Nieuwe high density Access Point
Een gebruiker van Insight Pro & de nieuwe WAC540 access points heeft een review op Techsite Hardware.Info.nl gepost: "De apparatuur presteert heel goed en biedt veel gemak. Het is wat mij betreft echt een product voor bedrijven die snel aan de slag willen zonder veel gedoe. Wil je zelf meer doen en alles tot in de puntjes tweaken dan is het misschien niet voor jou. Ben je op zoek naar een toegankelijk product met veel gemak en een visuele interface, dan is dit een solide keuze." Lees meer op Hardware.info -review WAC540Review WAC540 - Nieuwe high density Access Point
Een gebruiker van Insight Pro & de nieuwe WAC540 access points heeft een review op Techsite Hardware.Info.nl gepost: "De apparatuur presteert heel goed en biedt veel gemak. Het is wat mij betreft echt een product voor bedrijven die snel aan de slag willen zonder veel gedoe. Wil je zelf meer doen en alles tot in de puntjes tweaken dan is het misschien niet voor jou. Ben je op zoek naar een toegankelijk product met veel gemak en een visuele interface, dan is dit een solide keuze." Lees meer op Hardware.info -review WAC540Review nieuwe WAC540 - high density access points
We hebben een 3-tal prijzen op Hardware.Info verloot in de vorm van éen PoE-switch (GC510P), 3x 'van onze hagel nieuwe high density access point de WAC540 en licenties voor ons Insight Pro cloud beheer platform. Eén van de winnaars heeft zijn eerste review geplaatst. Lees meer op Hardware.info - productervaring- netgear-insight-wac540-productervaring-door-tmanders
