Pugfom's avatar
Pugfom
How to configure WAC510 to prefer 5.0 Ghz band over 2.4 ghz band
my devices are connecting to the 2.4 Ghz band when the faster 5.0 band is available.  Is there a way to configure the WAPs to prefer the faster 5.0 ghz band?
  • Hi Pugfom,
    You can enable the Bandsteering feature on your WAC510, which steers the Wireless devices (Dual band Capable) to the 5 Ghz band.
    To configure this from Web UI,
    Login > Management > Confgiuration > Wireless (Basic) > WLAN Settings > Under preferred SSID#
    Do check for the attachment for reference, hope this helps.
    Please note :
    Band Steering largely depends on the Wireless environment aroud like (Interference, Congestion etc)
    Thanks,
    Salauddin
  • Hi Pugfom,
    Please note :
    Thanks,
    Salauddin
    • RaghuHR's avatar
      RaghuHR
      NETGEAR Expert
      Hi Pugfom
      Are you able to check the band steering feature as explained by SalauddinK.
      Let us know if you have any questions. If you are satisfied then you can mark this thread as 'Accept as solution'
      Thanks
      Raghu
    • schumaku's avatar
      schumaku
      As this is under the NETGEAR Insight Management App subforum, I fail to see this as a solution. How/where can we enable Bandsteering for the WAC505/WAC510 in IM3?
      • fordem's avatar
        fordem
        Mentor
        The insight app is now at ver 4 - I still don't see a way to enable band steering from the app.
ProSupport for Business
