Pugfom
Nov 18, 2017Aspirant
How to configure WAC510 to prefer 5.0 Ghz band over 2.4 ghz band
my devices are connecting to the 2.4 Ghz band when the faster 5.0 band is available. Is there a way to configure the WAPs to prefer the faster 5.0 ghz band?
- Nov 19, 2017
Hi Pugfom,
You can enable the Bandsteering feature on your WAC510, which steers the Wireless devices (Dual band Capable) to the 5 Ghz band.
To configure this from Web UI,
Login > Management > Confgiuration > Wireless (Basic) > WLAN Settings > Under preferred SSID#Do check for the attachment for reference, hope this helps.
Please note :
Band Steering largely depends on the Wireless environment aroud like (Interference, Congestion etc)Thanks,
Salauddin
SalauddinK
Nov 19, 2017NETGEAR Expert
Hi Pugfom,
Please note :
Thanks,
Salauddin
RaghuHR
Nov 27, 2017NETGEAR Expert
Hi Pugfom
Are you able to check the band steering feature as explained by SalauddinK.
Let us know if you have any questions. If you are satisfied then you can mark this thread as 'Accept as solution'
Thanks
Raghu
