HarmonHodge
Jul 23, 2023Star
Resubscribe for WAX 620
After a year my subscription has expired on the WAX 620. it isn't the easiest to find how to resubscribe. After searching, I find three prices. I chose the $79. per year as I use this at home and not...
- Jul 23, 2023
HarmonHodge wrote:
I can download the firmware to my Mac but cannot I stall it on the wax 620. I also tried logging in directly to see if I could do anything but that fails.What happens when you try?
I see no suggestion in the manual that you have to have a subscription to update the firmware. Indeed, it has instructions on how to do it manually.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manualManually download firmware and update the access point
michaelkenward
Jul 23, 2023Guru - Experienced User
HarmonHodge wrote:
All I want to do is keep the device up to date.
I doubt if you need to subscribe to anything to do that.
Support | NETGEAR
That page will also have any software, firmware and drivers for your device, if they exist.
Firmware updates will also be there.
