HarmonHodge
Jul 23, 2023Star
Resubscribe for WAX 620
After a year my subscription has expired on the WAX 620. it isn't the easiest to find how to resubscribe. After searching, I find three prices. I chose the $79. per year as I use this at home and not...
- Jul 23, 2023
HarmonHodge wrote:
I can download the firmware to my Mac but cannot I stall it on the wax 620. I also tried logging in directly to see if I could do anything but that fails.What happens when you try?
I see no suggestion in the manual that you have to have a subscription to update the firmware. Indeed, it has instructions on how to do it manually.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manualManually download firmware and update the access point
HarmonHodge
Jul 23, 2023Star
Thank you. I will give it a try. I use Insight. It reads updates available but will not let me access. I also have a WAX601Y with the years support. It allowed me to up date it. I really have no need for support as this is for home use. I will try the links.
Thank you
Harmon
schumaku
Jul 23, 2023Guru - Experienced User
The WAX610Y can be integrated with the Insight management, along with the WAX620, into the same location of course.
