HarmonHodge
Jul 23, 2023Star
Resubscribe for WAX 620
After a year my subscription has expired on the WAX 620. it isn't the easiest to find how to resubscribe. After searching, I find three prices. I chose the $79. per year as I use this at home and not...
- Jul 23, 2023
HarmonHodge wrote:
I can download the firmware to my Mac but cannot I stall it on the wax 620. I also tried logging in directly to see if I could do anything but that fails.What happens when you try?
I see no suggestion in the manual that you have to have a subscription to update the firmware. Indeed, it has instructions on how to do it manually.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manualManually download firmware and update the access point
HarmonHodge
Jul 23, 2023Star
Yessir. I have done that. Works great. I purchased the wax620 a year ago and the wax610y recently. Works great. I just lost the ability to up date the wax620 when the support expired. NetGear doesn’t seem to want to take money on weekends and send a key for me to renew. I can download the firmware to my Mac but cannot I stall it on the wax 620. I also tried logging in directly to see if I could do anything but that fails.
Thank you
Harmon
Thank you
Harmon
michaelkenward
Jul 23, 2023Guru - Experienced User
Support | NETGEAR
