JohnMLCL
Feb 16, 2026Follower
WiFi Network not passing VLAN
I am having issues with my Insight Managed WAC540 to properly connect to a VLAN. If I send data untagged, it works perfectly fine on the default VLAN for the device, but I assign a SSID to be on a g...
schumaku
Feb 19, 2026Guru - Experienced User
Hello JohnMLCL
JohnMLCL wrote:(phone is able to connect to the WiFi, but it gives a 'no internet' error, and assigns an ip of 192.168.10.x .... I do not have any DHCP running on any vlan that assigns at x.x10.x)
Have by accident defined the specific SSID for that WiFi network to NAT Mode? Than the AP will operate a local-only IP subnet including a DHCP server for that SSID.
Local Web UI; Advanced -> Addressing and Traffic -> NAT Mode
resp.
WLAN -> SSIDx -> Network Settings -> Addressing and Traffic -> NAT
...and some subnet address and mask somehow matching 192.168.10.x
This would make the WAP acting as a NAT router, hiding all traffic under the WAP configured LAN IP address however.
JohnMLCL wrote:I am having issues with my Insight Managed WAC540 to properly connect to a VLAN.
If I send data untagged, it works perfectly fine on the default VLAN for the device, but I assign a SSID to be on a given VLAN, and it just doesn't connect to the VLAN.
Very unclear.
Talking of the WAP "LAN" interface which you intend to operate on a dedicated subnet on a tagged management VLAN?
