Akari
Sep 11, 2024Aspirant
"404 not found" is given when logged into "Main UI"
Hello, We were configuring the "M4250-26G4F-PoE+". When we tried to log in to the "Main UI", we suddenly got the message "404 not found." The AV UI is working fine. The firmware used is 13.0...
Akari
Sep 19, 2024Aspirant
Hello Erwin,
Thank you for your reply.
Right.
I clicked on the button in the attached image.
Then “404 not found” will be displayed.
Another switch (M4250-10G2F-PoE+) caused the same problems.
Is there any solution?
Best regards,
Akari
ErwinL
Jan 13, 2025NETGEAR Moderator
Hello Akari
Have you tried accessing it from a different computer? I do not remember if we have issue about this. Are they brand new switches?
Have a lovely day,
Erwin
Netgear Team
- LaurentMaJan 13, 2025NETGEAR Expert
Hi,
Very sorry - I hope the HTTP GUI wasn't disabled previously by a previous user (if so, CLI needs to be used to undo the commands). For now, can you try to access http://[IP address]:49151/v1/base/cheetah_login.html
Replacing [IP address] by your switch IP address?
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
