Fabrice50
Jan 08, 2025Aspirant
Configuration for both Qlan and Dante
Hello, i have an audio installation using Qsys Cores with Qlan and Dante software with a primary and backup audio network in redundancy. there is only audio in that network So my primary and ba...
- Jan 08, 2025
Hi Laurent,
Well...... it's so simple!
i didn't know the Qsys profile would handle directly Qlan and also Dante!
Thank you for your Quick answer,
Fabrice
LaurentMa
Jan 08, 2025NETGEAR Expert
Hi Fabrice50 ,
Don't worry, it's very simple: the multicast is handled automatically by the NETGEAR IGMP Plus, and the QoS (DSCP etc.) by the various AV profiles in the AV User Interface and/or the NETGEAR Engage Controller.
Since you have several switches, please do this:
- Install the NETGEAR Engage Controller on your PC or Mac from there: https://www.netgear.com/support/product/engage-controller/#download
- Onboard your switches
- Upgrade their firmware as Engage is saying so
- Go to Site Settings, and edit the Default VLAN
- Select the Audio Q-SYS template, and apply, apply, apply everything else
- Save in the upper right
- Done, your network is ready for everything QLAN, QSYS control, and Dante Audio
All steps are explained, app notes after app notes, if you follow our directions there:
https://www.netgear.com/hub/business/av/av-tech-guides/
If you have any issues, you can always reach out to the ProAV Design team, sending us an email at [email protected]
- Fabrice50Jan 08, 2025Aspirant
Hi Laurent,
Fabrice
- LaurentMaJan 08, 2025NETGEAR Expert
Hi Fabrice50 ,
Thank you, and yes - this was a very important improvement to the NETGEAR AV Line approx. one year ago in terms of Quality of Service (DSCPs, PTP, etc.) that the picture below describes nicely. From now on, any AV profile in the AV user interface and the Engage controller implements the same, unique, do-it-all QoS strategy. As a result, you can run Dante, Q-SYS, AES67, etc. using any of the profiles, anyway:
Thank you for using the NETGEAR AV Line for your AV over IP installation!
Laurent
- Fabrice50Jan 09, 2025Aspirant
Hi Laurent,
In the Qsys profile configuration page there is a PTP-TC Option.
When should i use it ?
Fabrice
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
