Fabrice50
Jan 08, 2025Aspirant
Configuration for both Qlan and Dante
Hello, i have an audio installation using Qsys Cores with Qlan and Dante software with a primary and backup audio network in redundancy. there is only audio in that network So my primary and ba...
- Jan 08, 2025
Hi Laurent,
Well...... it's so simple!
i didn't know the Qsys profile would handle directly Qlan and also Dante!
Thank you for your Quick answer,
Fabrice
Fabrice50
Jan 09, 2025Aspirant
Hi Laurent,
In the Qsys profile configuration page there is a PTP-TC Option.
When should i use it ?
Fabrice
LaurentMa
Jan 09, 2025NETGEAR Expert
Please leave it Disabled as it is by default.
PTP-TC is stamping PTP packets with the residency time in the switches (delay_req field) and you can notice it is enabled by default in AES67 Audio profile, because InterComm systems in general require it, coming from Broadcast/SMPTE world.
In the Q-SYS profiles, we set it disabled by default, because most installations don't require it. It comes down to how your Q-SYS Designer is configured. If you don't know about it, I would advise to let the PTP-TC disabled for now.
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
