bryandhargrave
Jan 26, 2023Initiate
Device won't connect to M4250-10G2F-PoE+
I use M4250 switches in racks with audio amplifiers made by Martin Audio. Each rack has 3 amps and each amp has 2 NIC that connect to a M4250. Of the 6 NIC, 1 of them will not connect to the swit...
- Jan 27, 2023
If anyone cares, a buddy of mine solved this for me as he had a device in the past that just refused to connect to another device.
Turned off auto negotiate on that switch port and set to full duplex. As soon as I saved, the activity lights started blinking and my device showed up on the network within seconds.
bryandhargrave
Jan 27, 2023Initiate
JohnHenkel
Jan 27, 2023NETGEAR Expert
We do care, thanks for sharing! Glad you found the solution.
For any future issues, your best bet for fast responses is to just email the Pro AV Design team: [email protected].
Best,
John
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
