adamfon
Jun 05, 2024Follower
Disable Auto-Trunk on a PER-PORT basis on M4250 AVline Managed Switch
Is there a way to disable Auto-Trunk on a PER-PORT basis? I work in the concert touring industry providing live video systems, and we have several M4250 AV Line switches in our average production...
BrianL
Jun 07, 2024NETGEAR Moderator
Hi adamfon,
Welcome to the Community!
Unfortunately, this is a global setting that we can only enable/disable on the device. You may want to submit a feature request here.
Reference: https://kb.netgear.com/000064378/aDDRDGONLTlSOrxpTFBkcbsGVxauaOIW
Kind regards,
BrianL
- LaurentMaJun 07, 2024NETGEAR Expert
Hello,
Correct, Auto-Trunk is enabled at the platform level on M4250/M4300/M4350/M4500, and that is a good thing.
But we still can disable Auto-Trunk on a PER-PORT level, manually:
Here is the workaround you want to use:
1. Disable LLDP transmit on port can stop send auto-trunk to peer device by port level.
2. Disable LLDP receive on port to reject peer device auto-trunk by port level.
You can do it in the IT GUI, but even easier using the CLI (AV UI Diagnostics\Terminal) in your browser:
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
