simonleungxyz
Apr 10, 2024Aspirant
How to disable TCP Port 4444
Greetings! I was told by the network security guy saying that my M4250 switch has a vulnerability on TCP Port 4444, I found out it is using on the web based terminal window on the admin gui. I ha...
- Apr 10, 2024
Generally valid answer is to put up some ACL to the switch config.
schumaku
Apr 10, 2024Guru - Experienced User
- simonleungxyzApr 10, 2024Aspirant
Hi schumaku , thanks for getting back. Yup, I have just put in a few lines on the IP ACL to block the questioning port. Have a good day!
Simon
- ErwinLMay 07, 2024NETGEAR Moderator
Hello simonleungxyz
Was your question answered? In this case could you give us feedback on the situation and accept the posts here as a solution to make it more visible to other users?
Thanks in advance!
Have lovely day,
Erwin
Netgear Team
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
