simonleungxyz
Apr 10, 2024Aspirant
How to disable TCP Port 4444
Greetings! I was told by the network security guy saying that my M4250 switch has a vulnerability on TCP Port 4444, I found out it is using on the web based terminal window on the admin gui. I ha...
- Apr 10, 2024
Generally valid answer is to put up some ACL to the switch config.
schumaku
Apr 10, 2024Guru - Experienced User
simonleungxyz
Hi schumaku , thanks for getting back. Yup, I have just put in a few lines on the IP ACL to block the questioning port. Have a good day!
Simon
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
