simonleungxyz
Apr 10, 2024Aspirant
How to disable TCP Port 4444
Greetings! I was told by the network security guy saying that my M4250 switch has a vulnerability on TCP Port 4444, I found out it is using on the web based terminal window on the admin gui. I ha...
- Apr 10, 2024
Generally valid answer is to put up some ACL to the switch config.
simonleungxyz
Hi schumaku , thanks for getting back. Yup, I have just put in a few lines on the IP ACL to block the questioning port. Have a good day!
Simon
ErwinL
May 07, 2024NETGEAR Moderator
Hello simonleungxyz
Was your question answered? In this case could you give us feedback on the situation and accept the posts here as a solution to make it more visible to other users?
Thanks in advance!
Have lovely day,
Erwin
Netgear Team
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
