vincelaus
Nov 24, 2023Aspirant
How to prevent NVY traffic to go out of M4300 ?
Hi I have a system where I use the M4300 for Crestron NVX system (Video over IP system). So far the NVX system on the M4300 works perfect but I have an issue. To be able to control NVX devices I...
- Nov 24, 2023
Thank you, vincelaus
To answer your questions in the right order:
- Correct, please apply the "Video" profile to all ports. Don't create a new profile, it doesn't seem to me you need it. Instead, in the AV UI, go to Network Profiles\Configure page. Find the Configured Profiles table in the middle of the page. You should see Default VLAN 1 in the table. Use the three little dots on the right, and select Edit. In the popup edit window, find the Template dropdown menu, select it, find Video and select it. Click Apply to close the popup window. If you now see Video under "AV template" in the List of configured profiles, you're good. Click Save on the upper right.
- Yes, go to Multicast page, select the port going to the main network, and use the dropdown menu to select "Block". Click Apply. A small block icon will appear on the switch representation image, at the top of the page. Click Save (blue button) on the upper right again. So does all of it survives to the reboots.
- Yes, unlike M4250 or M4350, M4300 doesn't have Auto-Trunk and Auto-LAG enabled by default. You need to manually enable both in the AV UI. It's easy. At the top of the page "Network Profiles\Configure', toggle on Auto-Trunk. Click Save on the upper right. Next, go to Link Aggregation page, and toggle on Auto-LAG. Click Save again on the upper right.
- Auto-LAG will take care of everything for you, don't worry. Yes, for multicast, don't touch the Default L2 hashing algorithm, it's optimized to parse traffic based on multicast groups (Multicast MACs). Just connect the switches together with 2, 3, or 4 10G in between. For instance, the 2 10G copper ports using CAT6A cables. Or the 2 10G SFP+ ports using 10G DAC cables. Or all four ports all together if really you have that much traffic expected.
I think you're all set! Have a great weekend.
vincelaus
Hi LaurentMa
Thanks a lot for your very detailed answer.
For firmware I'll do it when I'm back on site as I'm not very much into doing that remotely.
I didn't create any VLAN as I use them basically in default configuration so I quess I need to deactivate as you suggest the IGMP Plus feature on the port used for link with rest of LAN. My only issue is that I don't have access at AV user interface. The M4300 (same on both units) only offers the standard login and no AV login aside as I had on an other unit for a different customer. Is there a specific URL I can use to get access to it ?
For info both switches right now are in version 12.0.17.6, B1.0.0.16 so not far of curent version.
For Engage I was not aware of that tool and I'm going to use it as you suggest (reset both switches, enroll them in Engage and do the setup this way). Just to be sure I reset both switches and from then I add them in a project in Engage ? I have nothing to do on switches out of resetting them ? Also Engage is able to use the OOB port to control/setup the switch ?
Side question: the OOB port works how ? I had difficulties in past to access it with default IP 192.168.0.239 Will it still use the fixed IP if it's plugged on a network that has DHCP server active ?
Thanks for all
Vincèn
LaurentMa
Nov 24, 2023NETGEAR Expert
Hi vincelaus,
Thanks, all good then. The default configuration on VLAN 1 (untouched) has IGMP Plus. Yes, it means we just need to block multicast on the port used for the main network.
This is because you have an old firmware. We introduced the AV UI approx. one year ago on M4300. Please upgrade the firmware to the latest from and you will then see it. When you point your browser to the switch management IP address (OOB or VLAN 1), you will see two logins. On the left, direct login to the AV UI. On the right, a button for the IT GUI (the GUI you have already today).
Right, it is too old. Please upgrade to 12.0.17.15 from https://www.netgear.com/support/product/m4300#download
Since you are using VLAN 1 without real modifications, it's safe for you to just discover the M4300 switch in Engage, and onboard it directly (without factory-resetting it before). You don't have to worry! Since your firmware is very old, please update the switch before though, to the latest firmware . Onboarding will be easier, and faster.
Yes, you can use Engage with either the OOB ports of the M4300 switches, or the VLAN 1 directly. When you configure your "site", you just need to configure which NIC you are using, static IP or DHCP client NIC. You can also configure a static NIC and use it with a DHCP server in Engage, so that the OOB ports get an IP address from your computer when you configure them, as they are by default DHCP client. I gave the link to our app notes above (previous post), please review, we explain all this very well@!
The OO port, by defaut, is DHCP client. Right after the boot of the switch, the OOB is sending DHCP discovery packets in order to receive a DHCP address from a DHCP server. This is useful when there is a "management network" connecting all OOB ports in the network. When no DHCP server, the OOB port has unreachable 0.0.0.0 IP address at the beginning, after the boot. The boot itself takes 3 minutes, then the switch is online. Approximately 2 minutes after that moment (120 seconds after the end of the boot), the OOB port is reverting to 192.168.0.239 255.255.255.0 when there is no DHCP offer because no DHCP server on the OOB side. This is when you can start connecting to it using 192.168.0.239 only.
To answer your question, if a few hours later, or all a sudden a few weeks later there is a DHCP server on the OOB side, then it will take approximately 2 minutes to the OOB port to release 192.168.0.239 and get a DHCP client address. The reason is, even when the OOB port has reverted to 192.168.0.239, it is sending a new DHCP discover packet every ~ 2 minutes, just in case.
I hope this helps,
- vincelausNov 24, 2023Aspirant
Thanks a lot for all your explanations that make it a lot easier to understand.
I have upgraded both switches so now I have well the AV UI login 😉
If I have well understood your explanations:
- I apply on both Switches the Crestron profile on all ports.
- I block the Multicast on the port I use to connect the NVX network with main network.
- I activate in both switches the Auto-Trunk and Auto-Lag
- I'm all good, right ?
Just something about Auto-Lag, it doesn't ask anything about size of it (I'll do it physically linking one of the 2 10G ports of each switch together) but it asks for Auto-Lag Hash setup by default at Layer 2: Destination. Default is ok for it ?
Vincèn
- LaurentMaNov 24, 2023NETGEAR Expert
- vincelausFeb 04, 2024AspirantSorry for late answer and thanks again for your help, everything works fine since few months now 😉
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
