Zoi
May 12, 2026Initiate
M4250-26G4F-PoE++ - No opening browser nor AV UI - only USB Connection
Hi ! Any Netgear Specialist who could help us? We could just get access once to this switch . It has a qscsystems pass and we wanted to change the pass. It is an M4250-26G4F-PoE++ . This sw...
Zoi
Jun 01, 2026Initiate
Hi ! I finally could connect to the switch by console USB-c . We tried to Factory Reset the switch through console with no success. We have been in touch with Netgear ProAV support and they have checked all the Maintenance Logs and they have done an RMA to change this switch. We are still waiting for the switch to set up all again and test all the AV installation.
schumaku
Jun 02, 2026Guru - Experienced User
Zoi wrote:I finally could connect to the switch by console USB-c .
I'm still lost on what issue you had with the simple USB-C console, especially because you started the post under the subject "...only USB Connection".
Zoi wrote:We have been in touch with Netgear ProAV support and they have checked all the Maintenance Logs and they have done an RMA to change this switch
You might still require the Q-Sys specific config from Q-Sys support only. This is exclusively available for Q-Sys customers, e.g. after contact via the QSC Support Portal .
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
