BullringLive
Apr 01, 2025Aspirant
M4250 driver update issue
After support got my switch running. the switch has worked just fine. I updated it because I was going to trunk a new switch. After the update. I now have 2 cams showing on 192.168.12 and 2 showing u...
- Apr 07, 2025
Finally figured it out.
For some reason the 2 cams had reverted back to static ip addresses.
Not sure where the .100. came from as the cams factory setting was a .1. address
Whatever, its back to working
BullringLive
- BullringLiveApr 04, 2025Aspirant
I ended up resetting the switch and used engage to get it setup.
I just changed the default DATA to NDI on all the ports
To add a vlan for DATA. do I just leave the dhcp stuff greyed out so that I can it gets seen by my ip scanner?
Can I just copy the Engage exe file to a usb stick so I can control from my home and location I work from?
- BullringLiveApr 07, 2025Aspirant
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
