lrbarrios
Aug 10, 2021Aspirant
M4300 IGMP Snooping table empties after working
I have several M4300 24x24 switches and 1 M4300-96X as the core (all running latest firmware -- 12.0.13.7). I'm streaming video around the building. The configuration is correct. When it works, it...
- Aug 13, 2021
I'm happy to report that lrbarrios ZeeVee Zyper4K network on mutliple M4300 switches work great now. The NETGEAR ProAV Design team ([email protected]) helped Lonnie and reconfigured the switches all together. NETGEAR M4300 series is pre-configured for perfect multicasting out of the box, with IGMP Plus taking care of the multi-switch IGMP dynamically and automatically, but all the IGMP configuration is at the VLAN level. Instead, Lonnie followed another method with IGMP added config at the physical port (interfaces) level, and it was conflicting bad with IGMP Plus and the VLAN config. We simply removed any IGMP config from the interfaces, and the VLAN config was already there, untouched, so default. Lonnie confirmed since then that the overall AVoIP network was working great!
Everyone, don't be shy - reach out to the NETGEAR ProAV Design Center anytime, and we will help you on AV-over-IP switching, any type.
LaurentMa
Aug 13, 2021NETGEAR Expert
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
