BrettHM's avatar
BrettHM
Follower
Nov 08, 2021
M4300 will not get IP address from Google Fiber modem/router
Any idea why devices plugged into an M4300 switch will not get IP addresses from a Google Fiber Modem/Router unit?  If I plug the switch into another router of my truck it works fine.  However all other devices in the network are working fine with the Google unit.  I have tried 2 M4300 units and they both do the same thing.
1 Reply
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    BrettHM,
    Just found out that you have already contacted NETGEAR Support with regard to your concern.  You may want to post the progress of it.
    DaneA
    NETGEAR Community Team
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
