Bishop_A's avatar
Bishop_A
M4250 / M4500 - Engage Presets - Lighting
A query around using Engage to configure an sACN system for an ETC Eos family control setup.    I have previously manually configured a Lighting VLAN using various M4250 range products and I am now...
  • LaurentMa's avatar
    Nov 29, 2024
    Hi Bishop_A ,
    We are not certified at ETC Lighting with the current Lighting profile (AV UI and Engage are the same, they share the same profiles).
    But we went through the process and we have a new ETC profile in the works that should be live when we publish a new Maintenance Release (Engage and switch firmware's) during the first week of January.
    For now, you can reach out to the NETGEAR ProAV Design team (email at [email protected]) but I can give you these directions in Engage:
    - Use the Default VLAN 1 if you can, as it's already a Layer 3 VLAN (IP Interface on it) - ETC requires a Layer 3 VLAN
    - If you have other AV VLANs to do, you can create other VLANs using other AV templates, no problem
    - In Engage, under Site Settings, edit the Default VLAN 1 and assign the Dante Audio template to it, it's the closest currently to what ETC future profile will do
    - Apply and Save
    - In Engage, go to the list of Managed Devices, and click "Configure"
    - Go to the Interface Configuration, select all ports, and Disable the Broadcast Storm Protection
    - Click Apply
    - Then Save at the top
    You should be ready to go on the Default VLAN 1 for the ETC Lighting.
    All IT settings applied can be visualized in the IT GUI, should you want to take a look - but to me there is no need!
    Thank you,
    Laurent
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
ProSupport for Business
