Zoi
May 12, 2026Follower
M4250-26G4F-PoE++ - No opening browser nor AV UI - only USB Connection
Hi ! Any Netgear Specialist who could help us? We could just get access once to this switch . It has a qscsystems pass and we wanted to change the pass. It is an M4250-26G4F-PoE++ . This sw...
schumaku
May 13, 2026Guru - Experienced User
The first line for support of QSC switches (manufactured by Netgear) remains with Q-SYS.
Log in to the QSC Support Portal using your QSC ID. This will allow you to view your current status and communicate with your assigned support technician as needed.
As the NETGEAR Community, we don't know what special configurations like a qscpassword or the like might be in place.
FMI:
What does output does the serial console port (convenient implemented as a USB Port) give you?
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
