asu21's avatar
asu21
Tutor
Dec 01, 2021
RBR50 Can't work with Alaaddin Connect Garage Door Opener
Hi, I have an Orbi Mesh system (RBR50) that will not allow me to connect to my wifi garage door opener.  Any recommendations?
Thanks.
Alan
  • Turns out the computer board was bad. Got a new one from Genie (free because it is still under warranty), replaced it, and it works now.
  • plemans's avatar
    1. what gateway is the router connected to?
    2. what firmware is on the router?
    3. How are you setting up the opener and where is it failing in the process? I actually have an aladdin connected to my system.I initially installed it to my orbi RBR50 system. So I'm curious where its failing in the process?
    • asu21's avatar
      asu21
      Tutor
      Hi, I am not sure what gateway I was using. How do I find out? Firmware is 2.7.3.22. I used Genie’s app on my phone to connect the motor to my home system. At first, their network (gdocntrl-xxxx) would not show up after I pushed the WiFi button on the motor itself. After unplugged and plugged in the motor, their network showed up. From that point, I followed the process and it failed when it was trying to connect back to my home system. Once that happened, their network disappeared and I had to unplugged/plugged in the motor again in order for their network to show up again. Finally after many tries, by chance, it connected to my system. However, it kept disconnecting after a few minutes. I spoke to Genie’s rep and they couldn’t figure it out either. They are going to send me a new board. It’s ironic that I just had my new opener installed yesterday. How did you get it to work?
      • plemans's avatar
        Its been a while since I had to connect mine but it was a simple push button operation between the opener and the app.
        The gateway would be the modem/ONT/device that the router connects to that supplies an internet signal.
    I suspect you're trying to use their phone app and it is getting confused because your phone connects to the 5Ghz Orbi network and erroneously passes that to the Aladdin system which only supports the 2.4Ghz Orbi network.
    Fortunately it looks like there is a secondary way to perform the wi-fi setup (similar to Chamberlain/Liftmaster MyQ).  After you connect to the Aladdin's wifi (gdocntrl-xxxx), use a web browser to configure it,  That web browser lists and lets you select amongst the 2.4Ghz networks the Aladdin sees (instead of relying on what your phone connects to):
    I’ve tried this approach to connecting my device and it’s just not working. Are
    there any other ways to setup Wi-Fi?
    Yes, there is a second approach to passing the Wi-Fi network and password
    that uses an embedded webpage in the door control module when it is in
    configuration mode. To use this method, press and hold the Wi-Fi button
    until the device beeps. When the LED changes from red to yellow, go to
    the Wi-Fi settings on your smartphone and connect to the gdocntl network.
    Once you are connected to the gdocntl network, go to the web browser on
    a smartphone or computer and enter https://192.168.1.1. This connects
    you to an embedded webpage in the door control module. Click on the
    configure button. The embedded webpage takes you to a set up screen.
    Here, you will select the home Wi-Fi network from a list of available
    networks, keep the WPA2 encryption selection, and then scroll down, enter
    the password for your home W-Fi network, keep the default service
    selection, and then select save. After hitting save, the first part of the
    configuration is complete, and the door control module connects to the
    home Wi-Fi network.
    Once the door control module is connected to the home Wi-Fi network, the
    next step establishes a secure communication link between the door
    control module and the cloud. Press connect to submit the configuration
    and complete Wi-Fi set up. The cloud and the door control module will
    exchange keys/tokens, so a secure communication link is established. The
    LED will change to solid green. If the LED is flashing green, the connection
    to the cloud was not successful.
    • asu21's avatar
      asu21
      Tutor
      Thx for the advice. I will try this out.
    • asu21's avatar
      asu21
      Tutor
      Tried using my laptop to connect, and still didn’t work. Contacted Genie’s rep and they had no idea why either. They will send me a new control board for replacement. Hope it will work after.
      • asu21's avatar
        asu21
        Tutor
