AKC_Alois
Jun 27, 2025Aspirant
SDVoE system advice - routing without PC
Hello, is it possible to do something like on picture shown bellow with SDVoE system? Whatever you put into Input X, must be routed to all output Xs If you plug 2 or more cables to input X, sw...
schumaku
Jul 20, 2025Guru - Experienced User
AKC_Alois In case you don't want to go the (in my opinion the least expensive, exactly as per your design drawing - but know-how dependant) way with "hard" defined VLAN access ports according to your design intention, some vendors of SDVoE encoder and decoder (aka. transceivers and receiver) boxes also offering SDVoE network controllers allowing to dynamically configure groups using a WebUI at an additional cost. Keep in mind not all appear per-se purely SDVoE "de-facto standards" based, many depend (eg. for simple device control and discovery) on vendor specific functionality. At least this is what the various vendors product descriptions and data sheets state.
Not sure a basic capture card (requiring a powerful PC for full 4K@60 4x2x0 or a slightly compressed 4x4x4) is able to do - again please look at the SDVoE Signal Processing systems (Transceivers or Encoders) on https://products.sdvoe.org/avcat/ctl18883/index.cfm?category=signal-management-processing
If things are still unclear, please don't hesitate talking to the Netgear Pro AV Design Services by form, or by email mailto:[email protected] - a professional worldwide group of Netgear Pro AV engineers is at your hands - at no cost. LaurentMa
Master AV-over-IP networking, multicast protocols, and troubleshooting to confidently deploy and manage AV networks.
