Jan 14, 2022Guide
5ghz power
Hello, I am able to adjust the 2.4ghz transmit power on the orbi pro wifi 6 mini AX1800 SXK30, but the 5ghz transmit power is grayed out and not adjustable. I have the 2 satellites with ether...
Jan 14, 2022Guru - Experienced User
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
I also noticed this as well, I haven't checked my system again and noticed there is a new FW update:
Not sure if this changes anything.
- plemansJan 14, 2022Guru - Experienced User
That firmware version doesn't change it. Its still grayed out.
I confirmed on mine that its grayed out as well.
I think a couple months ago I brought it to a mod's attention but found out it was set that way and not a bug.
Not sure why.
