AlexW22
Aug 11, 2021Aspirant
add a wired device to LAN
Hi there , Can anyone tell me how to move a wired connected device to another LAN? I want to move a device from LAN 1 to LAN 3, but the assigned ip address is in LAN 1 range. And I want this device...
Aug 12, 2021Guru - Experienced User
If you log into it using the browser, go to Advanced---->advanced setup----->vlan/bridge settings.
there you should be able to change which port is associated with which vlan and the specific client isolation/network association for that vlan.
AlexW22
Aug 12, 2021Aspirant
I do not want a lan port assigned to a vlan, I want a move a wired connected device moved to another lan, in this case lan 3, which has the iot vlan assigned to it. If I assign a whole lan port to vlan, everything connected to it will also be on the vlan.
