Mar 02, 2021Aspirant
Added SRS60 to SRR60 in AP mode. Was identified in device list but SRS60 IP address is 10.1.10.56.
Added a second Satellite, SRS60, to a new Orbi Pro AC5 system. The router found the add-on satellite, but the Satellite came up with the IP address of 10.1.10.56. The Router is in AP mode and the I...
- Mar 04, 2021
Thanks to both responders. I discovered after some frustrating work on Wednesday that another DHCP source was added to the network and it's handing out 10.1.10.x addresses when it wins the DHCP request; otherwise, the primary DHCP source wins and supplies the 192.168.1.x address. Thanks to the features of ORBILOGIN, the attched devices map clearly showed every device on the network and the smattering of both 10.1.10.x and 192.18.1.x networks. Also, I used an iPAD 5 with an Ethernet adapter and, with Wifi on as well, got a 192.168 address on one and a 10.1.10.x address on another.... We're going to work in the main office tomorrow and track down the second DHCP source...wish me luck! Thanks again for your consideration and suggestions.
schumaku
Mar 03, 2021Guru - Experienced User
How is this SRS60 connected to the network? The only thing coming into my mind would be that the SRS60 had a static IP configured from a previous installation, or it's wired to a switch port where the port is configured to a different VLAN with a DHCP server from a different subnet 10.1.10.x or 10.1.x.x or 10.x.x.x.
