capin
Sep 30, 2022Tutor
Adding mDNS services for Orbi Pro 6
I would like to have a isolated vlan with limited service access to a page hosted on port 443 from another vlan. Is that possible? I was thinking mDNS would be a possible solution but I only see chro...
- Oct 06, 2022
When you enable mDNS from one VLAN to another, it exposes everything on those hosts to the target VLAN I've found. I assume this is because it would be a headache to parse the mDNS advertisement for every service and create an iptables rule for each one.
If you want to expose one or two services between VLAN's, then a host that is attached to both sides would be the easiest and most secure. You could either proxy the connection using traefik, caddy, or even just straight iptables.
The mDNS feature added by NetGear is mostly just a 1 directional convenience tool to allow access IoT devices to be accessed easily. I think you're asking too much from it. It's barely better than an mDNS-repeater.
archite
Oct 06, 2022Star
capin
Oct 07, 2022Tutor
Thank you so much for the help with this archite! Your posts have been really informative!
I like the idea of just having a simple device on both vlans and setting up iptables for port forwarding, but don't have something lying around I could use for that.
Now, I'm thinking of setting up a pfsense firewall appliance and setting that up between my orbi and internet connection, have that create the vlans and set the orbi to access point mode. Let me know if you have any thoughts on that.
Thanks again!
- architeOct 07, 2022Star
That would work but make sure it has enough resources to handle the speed of your connection and the number of clients you plan on having within the network and ensure the CPU has support for AES-NI. I've thought about doing this myself but didn't want o drop $800 to support my gigabit internet.
- capinOct 07, 2022Tutor
All great points! This is quickly turning into a maybe next year kind of project... I really appreciate all of you insight! Thank you!
