BooJangles
Sep 25, 2019Apprentice
Advice for Wi-Fi to Ethernet Bridge/Adapter
Hello all, I currently have an Orbi Pro setup 1 SRR60 router and 6 SRS60 satellites. 5 are wired backhaul and 1 wireless across a multi home complex. They are installing some power monitoring eq...
- Sep 30, 2019
I agree and thought this would be the best solution but I am already at 6 satellites which I believe is the limit?
Actually, the Orbi Pro can now support up to 8 satellites. This might be the solution for your power monitoring equipment.
John
NETGEAR Community Team
JohnC_V
Sep 26, 2019NETGEAR Employee Retired
Hi BooJangles,
You can actually connect a switch directly to a satellite that is connected thru Ethernet backhaul instead of using a WiFi bridge. May you be able to share us your network topology in order for us to better understand what you want to achieve here.
John
BooJangles
Sep 26, 2019Apprentice
Unfortunately the wired satellites are not near the panels where these devices will be. There are also no cable runs to these locations hence looking for the best way to connect to the existing Wi-Fi .
Thanks
Thanks
- JohnC_VSep 27, 2019NETGEAR Employee Retired
I see. Is it possible for you to use a USB WiFi Adapter to this power monitoring equipment? If yes, then you may check these adapters if this will suffice. You may also create another thread in WiFi Adapters community.
Thank you!
John
- BooJanglesSep 28, 2019ApprenticeNo USB , only Ethernet.
- davidcheokSep 27, 2019Apprentice
ThanksRather than buy a whole bunch of devices to stick into your power devices, why not add a satellite and a cheap switch near those devices and add more robustness to your network at the same time? Less things to go wrong and less management hassle. The satellites can connect to the mesh and i doubt those devices will require large data throughput.
- BooJanglesSep 28, 2019ApprenticeI agree and thought this would be the best solution but I am already at 6 satellites which I believe is the limit?
Thanks- JohnC_VSep 30, 2019NETGEAR Employee Retired
John
