Sherminator's avatar
Dec 13, 2018
wireless bridge adapter?
Hi there,
in our local network we use some WAC720 access points. Now we would like to connect some LAN-only devices to our network at places where we don't have any wires. Are there any Netgear devices which can do something like a "wireless-to-wired"-bridging with our WAC720s?
Or do you have other suggestions to solve this problem?
Thanks a lot for your support and many greets
Stephan
  • Hello Stephan,
    1. Install a cable
    2. Install a cable
    3. Install a cable
    4. Desperately want to make you unhappy? Configure one existing WAC720 near to the area as a point-to-point device (AFAIK co-existing with the AP mode)  Add another WAC720 in WiFi bride (point-to-point) mode. WAC720/730 User Manual p.130 ff.
    5. If this is not good enough, start with #1 again.
  • schumaku's avatar
    schumaku
    Hello Stephan,
    1. Install a cable
    2. Install a cable
    3. Install a cable
    • Sherminator's avatar
      Sherminator
      Tutor
      Hey schumaku,
      thanks a lot for your fast reply!
      Yes, I think you're right. We really should consider installing cables.
      Many greets from Germany
      Stephan
      • schumaku's avatar
        schumaku
        Immer gerne!
        Grüsse aus der Schweiz
        -Kurt
ProSupport for Business
