BooJangles
Sep 25, 2019Apprentice
Advice for Wi-Fi to Ethernet Bridge/Adapter
Hello all, I currently have an Orbi Pro setup 1 SRR60 router and 6 SRS60 satellites. 5 are wired backhaul and 1 wireless across a multi home complex. They are installing some power monitoring eq...
- Sep 30, 2019
I agree and thought this would be the best solution but I am already at 6 satellites which I believe is the limit?
Actually, the Orbi Pro can now support up to 8 satellites. This might be the solution for your power monitoring equipment.
John
NETGEAR Community Team
BooJangles
Sep 26, 2019Apprentice
Unfortunately the wired satellites are not near the panels where these devices will be. There are also no cable runs to these locations hence looking for the best way to connect to the existing Wi-Fi .
Thanks
Thanks
JohnC_V
Sep 27, 2019NETGEAR Employee Retired
I see. Is it possible for you to use a USB WiFi Adapter to this power monitoring equipment? If yes, then you may check these adapters if this will suffice. You may also create another thread in WiFi Adapters community.
Thank you!
John
- BooJanglesSep 28, 2019ApprenticeNo USB , only Ethernet.
