Techdeskxy
Feb 08, 2024Aspirant
After doing the firmware update via the Insight app my Orbi pro stopped working
After doing the firmware update via the Insight app my Orbi pro stopped working. I have factory reset a couple of times but, still getting the same problem. The white light blinks for a while then it...
Feb 09, 2024Guru - Experienced User
have you checked to see if the IP address for the router changed? I've see a firmware update cause a reset (or you reset) and it defaults to a different iP address if there's a conflict
- TechdeskxyFeb 09, 2024AspirantAfter the reset I connected directly to the modem. And the modem is set with DHCP mode so the IP changes for the Orbi. Before I had these issues, I had the Orbi set on a static IP but I have since removed that.
- plemansFeb 09, 2024Guru - Experienced UserIt's the orbi in ap mode if the gateway is handling dhcp
- schumakuFeb 10, 2024Guru - Experienced User
Correct. The issue is much deeper and somewhere in the way Insight is implemented on these Orbi Pro - all 80, 50, and 30 models are affected - once updated, and with Insight enabled.
- TechdeskxyFeb 13, 2024AspirantI have not been able to reach the orbilogin.com or reach 192.168.1.1. In the modem it is showing another IP address but, I also have factory reset the Orbi. At the moment I am at a loss.
