Techdeskxy
Feb 08, 2024Aspirant
After doing the firmware update via the Insight app my Orbi pro stopped working
After doing the firmware update via the Insight app my Orbi pro stopped working. I have factory reset a couple of times but, still getting the same problem. The white light blinks for a while then it...
Feb 09, 2024Guru - Experienced User
have you checked to see if the IP address for the router changed? I've see a firmware update cause a reset (or you reset) and it defaults to a different iP address if there's a conflict
Techdeskxy
Feb 09, 2024Aspirant
After the reset I connected directly to the modem. And the modem is set with DHCP mode so the IP changes for the Orbi. Before I had these issues, I had the Orbi set on a static IP but I have since removed that.
- plemansFeb 09, 2024Guru - Experienced UserIt's the orbi in ap mode if the gateway is handling dhcp
- schumakuFeb 10, 2024Guru - Experienced User
Correct. The issue is much deeper and somewhere in the way Insight is implemented on these Orbi Pro - all 80, 50, and 30 models are affected - once updated, and with Insight enabled.
- TechdeskxyFeb 10, 2024Aspirant
Previously yes, it was in AP mode, but I have since done a factory reset. I gave one more chance. Last night, I set it up and left it with the pulsating white light. This morning it was a solid white light. I don't think there is anything else to do. It really too bad, the Orbi was working perfectly before doing the firmware update. I guess it's time to explore other options to purchase.
