Techdeskxy
Feb 08, 2024Aspirant
After doing the firmware update via the Insight app my Orbi pro stopped working
After doing the firmware update via the Insight app my Orbi pro stopped working. I have factory reset a couple of times but, still getting the same problem. The white light blinks for a while then it...
Techdeskxy
Feb 09, 2024Aspirant
After the reset I connected directly to the modem. And the modem is set with DHCP mode so the IP changes for the Orbi. Before I had these issues, I had the Orbi set on a static IP but I have since removed that.
Feb 09, 2024Guru - Experienced User
It's the orbi in ap mode if the gateway is handling dhcp
