Techdeskxy
Feb 08, 2024Aspirant
After doing the firmware update via the Insight app my Orbi pro stopped working
After doing the firmware update via the Insight app my Orbi pro stopped working. I have factory reset a couple of times but, still getting the same problem. The white light blinks for a while then it...
Feb 09, 2024Guru - Experienced User
have you checked to see if the IP address for the router changed? I've see a firmware update cause a reset (or you reset) and it defaults to a different iP address if there's a conflict
Techdeskxy
Feb 13, 2024Aspirant
I have not been able to reach the orbilogin.com or reach 192.168.1.1. In the modem it is showing another IP address but, I also have factory reset the Orbi. At the moment I am at a loss.
