Batman-15
Jul 17, 2021Tutor
Armor for SXK30 — Orbi Pro WiFi 6 Mini AX1800 WiFi System
Good Evening: I am looking at purchasing the SXK 30 Orbi Pro router & satlelite. I currently have a subscription to netgear armor and was wondering if someone can answer the following questions: 1....
Jul 19, 2021Guru - Experienced User
in addition to what schumaku said, if you've already got armor and want to keep it, you can set up the R6900P as the router and put the SXK system in access point mode.
You could either disable the wifi on the R6900P, use it as backup, or even use it to offload IoT devices or fixed position devices that are close to the router.
That'd let you keep the benefits of armor while using the mesh system's wifi
Batman-15
Jul 19, 2021Tutor
Thank you very much for your response! You give me some things to consider.
