JasperC's avatar
JasperC
Tutor
May 05, 2021
AX6000 Tri-Band Orbi Pro WiFi 6 - 24/7 network access, Scheduled-only internet access
AX6000 Tri-Band Orbi Pro WiFi 6. Firmware V3.2.3.100.
I have one LAN dedicated to my NAS. I would like 24/7 internal network access to this LAN, but I would only like this LAN to connect to the internet at scheduled times to update the NAS firmware and for backups. All other LANs need internet access 24/7.
Any ideas if this is possible? Thanks.
    • DaneA's avatar
      DaneA
      NETGEAR Employee Retired
      JasperC,
      As per checking the user manual of the Orbi Pro WiFi 6 here, it seems that there is no option to set a LAN with a scheduled time for internet access.
      What is the brand/model of your NAS?  Its possible that on your NAS, there are settings for backup schedule and schedule the updates.
      DaneA
      NETGEAR Community Team
      • JasperC's avatar
        JasperC
        Tutor
        DaneA
        Yes, that is the correct link user manual for my model number. I didn't see an option either. I was hoping I was missing something, but regrettably no. Bummer.
ProSupport for Business
