Stables's avatar
Stables
Initiate
Jun 17, 2022
Cannot update latest firmware 2.7.2.102 SRR60 and SRS60
Cannot do a manual update or automatic update from 2.7.0.122 to latest firmware
2.7.2.102 Auto update says "no new firmware update available" Manual update says firmware file is incorrect version....weird....
  • plemans's avatar
    When you're manually updating, are you making sure the router is getting the router version and the satellite the satellite version? I know it sounds stupid but I've seen people trying to install the satellite firmware to the router. (also, make sure to update the satellite first).
    • Stables's avatar
      Stables
      Initiate
      Yeah....updated manually before on previous versions so doing everything right but no result. any other suggestions?
      • plemans's avatar
        You extracted the file prior to trying to upload it? (i know it sounds stupid but have to ask)
ProSupport for Business
