oxyIT
Jan 29, 2024Aspirant
Can't access router configuration page also DHCP is giving out IP's slow
This is all I can get even though I am trying to access with the local ip Hmmm… can't reach this page It looks like the webpage at (local IP) might be having issues, or it may have moved permane...
- Jan 30, 2024
oxyIT wrote:This is all I can get even though I am trying to access with the local ip
It looks like the webpage at (local IP) might be having issues, or it may have moved permanently to a new web address.
ERR_SSL_KEY_USAGE_INCOMPATIBLE.
Known issue. See:There is a workaround in that thread, or you can use Firefox. Ultimately, it's up to Netgear to fix this.
CrimpOn
Jan 29, 2024Guru - Experienced User
The post does not describe the URL that it being opened.
- oxyITJan 29, 2024Aspirant
It would not let me post with the URL in my original post but I can try local 192.168.1.1 but also routerlogin.net does not work either.
- CrimpOnJan 29, 2024Guru - Experienced User
Thanks for the information. Yes, this forum software does not accept HTTP unless it is specifically entered using this symbol on the menu bar:
The Orbi Domain Name Service (DNS) module intercepts several search requests (orbilogin.com, orgilogin.net, etc.) and returns the IP address of the router itself. This is often 192.168.1.1, but when the Orbi router is connected to another router that has created a LAN subnet of 192.168.1.x, the Orbi creates a LAN of 10.0.0.x
What device is being used to access the Orbi web administration? (PC? Mac? tablet? smart phone?)
The correct IP address to use is the "gateway IP" that has been returned by the DHCP process.
On a Windows PC, the config /all command reveals what this IP address is.
p.s. I forgot the "obvious". If the IP address assigned to the device trying to open the Orbi web interface is xx.xx.xx.##, then the IP address of the router is going to be xx.xx.xx.1
