oxyIT
Jan 29, 2024Aspirant
Can't access router configuration page also DHCP is giving out IP's slow
This is all I can get even though I am trying to access with the local ip Hmmm… can't reach this page It looks like the webpage at (local IP) might be having issues, or it may have moved permane...
- Jan 30, 2024
oxyIT wrote:This is all I can get even though I am trying to access with the local ip
It looks like the webpage at (local IP) might be having issues, or it may have moved permanently to a new web address.
ERR_SSL_KEY_USAGE_INCOMPATIBLE.
Known issue. See:There is a workaround in that thread, or you can use Firefox. Ultimately, it's up to Netgear to fix this.
quagmire1
Jan 30, 2024Luminary
Known issue. See:
- oxyITJan 30, 2024Aspirant
The workaround in that thread did not work unfortunately. I will just continue to use firefox till hopefully this issues gets updated / fixed.
- TampaBaySailorFeb 01, 2024Guide
The delete Local State is no longer working in chrome.
- schumakuFeb 01, 2024Guru - Experienced User
Correct, useless workaround anyway.
Appropriate workaround there. Either way, Netgear and many other vendors need to update the self-signed certificates including the usage bits.
