oxyIT
Jan 29, 2024Aspirant
Can't access router configuration page also DHCP is giving out IP's slow
This is all I can get even though I am trying to access with the local ip Hmmm… can't reach this page It looks like the webpage at (local IP) might be having issues, or it may have moved permane...
- Jan 30, 2024
oxyIT wrote:This is all I can get even though I am trying to access with the local ip
It looks like the webpage at (local IP) might be having issues, or it may have moved permanently to a new web address.
ERR_SSL_KEY_USAGE_INCOMPATIBLE.
Known issue. See:There is a workaround in that thread, or you can use Firefox. Ultimately, it's up to Netgear to fix this.
TampaBaySailor
Feb 01, 2024Guide
The delete Local State is no longer working in chrome.
schumaku
Feb 01, 2024Guru - Experienced User
Correct, useless workaround anyway.
Appropriate workaround there. Either way, Netgear and many other vendors need to update the self-signed certificates including the usage bits.
